Moving shifter to foward location on f body t56
I am about to move the shifter to the foward position on a fbody t56 for use in a 66 chevyII.I will use the kit keisler makes for this unless someone has a better idea.Anyone used one?Do they work well?Any other options?
I've used two different ones, both of which I've purchased from Gearbox. The first was a red shifter but I don't know who really made it. It worked out very nicely. The second time, it ended up being the Keisler kit, which I didn't as much. It just wasn't as user friendly as the other one.
Also the instructions kinds sucked on both kits. You don't actually have to drill out the rail like it says, as you can cut the rail and flip it around to use the hole that's already there.
