Slave cylinder recomendations
Old 01-02-2012, 08:35 PM
3rdCoastPowerSports's Avatar
Default Slave cylinder recomendations
does it matter what brand of clutch slave cylinder i buy... im installing a spec stage 2 clutch and resurfaced LS2 flywheel... Need a Slave cylinder, found some good deals on aftermarket stock type slave cylinders. Any advice, experience anyone wants to share?
Old 01-03-2012, 07:38 AM
Save the manuals!
wssix99's Avatar
God yes! Get a GM design and NOT a Delco design. (They are different.) Many people here have put in a Delco (like me) to have it blow up on them right away. If you search you'll find a lot of other info on this. (I think the AutoZone slave may be a more economical choice but recall that some people may have had issues with that, also.)
Old 01-03-2012, 11:29 AM
SNLPerformance's Avatar
We offer a slave that comes with a 12 month warranty, they are OEM AP units.
Let me know.
Old 01-03-2012, 11:44 PM
therealcreeper's Avatar
autozone slave with AP cast into it, it's the same as GM
whatever you do just to NOT get a perfection/advance auto slave cylinder
Old 01-04-2012, 08:21 AM
Save the manuals!
wssix99's Avatar
Let me know.
This isn't so exciting on a (relatively) inexpensive part that is extremely costly (in time and effort) to install. I'm not even sure if a lifetime warranty would be exciting, either. Its just got to be proven as reliable.
Old 01-04-2012, 05:56 PM
ha thats funny because when i read SNL's post about a warranty on the slave cylinder i thought.... wounder if they are going to warranty the time and labor it will take me to change the slave if it goes out. Im headed to Auto zone for the slave mentioned in the above post. i wasnt bashen you SNL i just thought it was kinda funny
Old 01-04-2012, 07:34 PM
Save the manuals!
wssix99's Avatar
I'd say that getting a patent on a slave cylinder that can be installed without dropping the transmission would be a great thing, alas... I fear that the stick shift is going the way of the dinosaur...
Quick Reply: Slave cylinder recomendations
