T56 dimension
T56 dimension
Hey guys,
I need a dimension off a t56. I've found several sites that give lots of useful dimensions, but not the one I need.
I need a dimension from the center of the tail shaft, to the mount surface (on the trans where the rubber mount bolts)
I'm doing a swap and need this dimension so I know what will fit.
Thanks
Josh
Thanks
Josh
This should get you close...
Simple Google Search turned this up...
http://www.5speedtransmissions.com/6_speed.html
deminsions, dimension, dimensions, dimentions, dimesions, dimmensions, external, ls, ls1, ls1tech, manual, mount, t56, tail, transmission, width
