Another satisfied Tick Master Cylinder customer.
Had the pleasure of installing my new Tick Master Cylinder yesterday. Install was straight forward. I unbolted the brake master and moved it out of the way to make it a bit easier. Didn't have to move the wiring harness underneath of it. The adjustment was simple. I had a Tick Speed Bleeder already from a while back when I had the motor out of the car, so bleeding was a breeze. Probably put half a liter of fluid through it to make sure it was all fresh. Pedal is a little bit below brake pedal level. Goes into all gears great from a stop and has a nice firm feel. Much shorter travel than my previous master cylinder. No more pumping the clutch 10x before being able to get into reverse! Thanks for a great product.
