Affordable way to get 1pc Countershaft?
Old 02-14-2012, 04:59 PM
v8pwr's Avatar
Default Affordable way to get 1pc Countershaft?
I really want to be able to use 5th & 6th without worry. Does anyone know of an economical way to get a 1pc countershaft into an F body? I'm considering a T56 Magnum since it has one along with other upgrades but that's not a direct swap. The F body T56 Magnum is too expensive, any ideas/thought/input?
Old 02-14-2012, 06:17 PM
thesource's Avatar
What kind of power is your car making?
Old 02-14-2012, 08:22 PM
v8pwr's Avatar
Initially a 425-450 rwhp turning up to 7k rpms. Later I'd like to push past 550 with a stroker. I'd really like more rpms as well as the ability to use 5th & 6th. I know that some use them with a 2pc countershaft without issue while others have had problems. I would like to be worry free for my power level goals. I would not use nitrous in those gears either.
Old 02-14-2012, 09:17 PM
85MikeTPI's Avatar
The only production T56 1pc counters were the early viper units, which Dodge/Mopar started refusing to sell without a viper VIN (and claimed to only work with a viper input shaft) and the '06-'07 Z06 units.
As I wrote in the SSR-Hybrid PDF, the Z06 1pc isn't so bad, but the unique 5, 6, rev drive gears required to use it more than double the pricetag.
Old 02-15-2012, 07:58 AM
thesource's Avatar
Yeah the C6 Z06 cluster would be your best option but as said, you have to change out the 5-6 stuff that rides on it.
Old 02-15-2012, 11:49 AM
jmd
jmd's Avatar
PM me if you would consider going 32 spline MN6 direct bolt-in.
Quick Reply: Affordable way to get 1pc Countershaft?
