Are SPEC clutches zero-balanced?
I got my SPEC 3+ yesterday and need to get my stock flywheel resurfaced. Surfacing the flywheel in theory should not change it's balance. Assuming it's still zero-balanced, can I used it with the SPEC pressure plate right out of the box?
Our parts are balanced but, as mentioned in the paper-work included with the kit, you need to have the clutch balanced with your stock flywheel. This results from the stock wheel being balanced with the stock clutch and never having been balanced independently. Trust me on this...balance them together to avoid potential issues with vibration. Let me know if you have any further questions. Thanks!
Understood! Let me know if you have any further questions and if needed call me and I can issue an RMA and you can send the parts to us for balancing and resurfacing if needed. Thanks!
