Diamond Clutch Specials! One-time deals
Here's the deal. I have five (5) used, but resurfaced billet steel flywheels that I'm DYING to get rid of . They are all roughly stock weight (22-25lbs). Stock is actually 23lbs, but you get the idea. They are all made by different companies, but all the same material (billet nickel-alloy, 2xxx) and weight. Diamond Stage 2 -OR- Stage 3 basic kit + Resurfaced billet steel flywheel (stock weight) $555 shipped.
All these flywheels will work perfectly with the Diamond Clutch, guaranteed!
These flywheels all cost in the $270 range alone, and the Diamond Stage 2 clutch is normally $409, and the Stage 3 is $449. So you're saving ~$250!
