T-56 Reverse Lockout Solenoid...
Mine is broken at the mount that secures it to the transmission. It was the source of my transmission leak that i have been scratching my head over for months. Does anyone know where to get one? I cant seem to find it anywhere. If anything ill just plug it up and be careful shifting to 5th hahaha
I have the exact same problem as you, the sensor is broken off. I am assuming that this is also the cause behind me not having reverse lights when I back up.
Anyone?
Anyone?
Will GM ever lower their prices??
redbird, do you happen to know the part number for the reverse light switch?
I accidentally got the two confused, forgot they are 2 separate sensors, the reverse light being on the passenger side of the trans
I found the part number for anyone who might need it in the future.
Reverse Light Safety Switch Assembly
P/N 14069600
Available through: AC Delco (Amazon.com $13), GM Parts Direct, or Standard Motor Products (Summit.com $13)(SMP-LS205)
P/N 14069600
