Did Drill mod and it's worse!!!! help
Old 04-16-2012, 08:55 AM
dirkdiggler350's Avatar
Default Did Drill mod and it's worse!!!! help
So I did a set a motive 3.90 gears and drill mod over the weekend. Gears came out perfect no whine what so ever. The drill mod on the other hand made my clutch issues worse. The pedal always cought low which it still does, and i had the sticking pedal after spirted driving. But now if a rev the car more than 4500 rpm the pedal just goes limp and falls to the floor. After about a min if i pump it it will slowly go back up.
It's like flipping a switch, driving normal around town it's fine but once i go full throttle it just falls to the floor. I bled the system about 6-7 times, it was bad before but not like this .
Anyone else have this issue, this sucks i just wanna drive again.
Old 04-16-2012, 12:47 PM
Rare96LT1Formula's Avatar
Slave?
Old 04-16-2012, 04:18 PM
TheBlueKnight's Avatar
So before the drill mod you could foor it and stuff and it did great but now after doing the drill mod it is dropping to the floor?
Old 04-16-2012, 07:11 PM
Update, ended up reading a lil more and decided to try and pull the clutch pedal spring and so far it is working. It also took out any play in the pedal and really tightend it up. I really haven't had a chance to really get on it cause I'm breaking in the gears but so far so good
Old 04-16-2012, 08:38 PM
VincesSS's Avatar
That ain't gonna do it.
Old 04-17-2012, 07:31 AM
Im still gonna spring for a tick master soon, but for now this will work.
Quick Reply: Did Drill mod and it's worse!!!! help
