Do I need a new clutch?
Old 04-30-2012, 02:00 PM
t56transam's Avatar
Default Do I need a new clutch?
When I first got the car it only would make a strange grinding noise when releasing the clutch rarely. Now it happens daily, also when the car is idling there is a weird loose metal sounds. If the tap the gas when in neutral the metal sound gets faster. Im thinking that I will need a new clutch and maybe throw out bearing.
Any help would be appreciated. The car has 132,000 miles
Old 04-30-2012, 09:20 PM
John510's Avatar
to bearing
Old 05-01-2012, 01:34 PM
t56transam's Avatar
Thanks, do you think it is worth upgrading the clutch while under there?
Old 05-01-2012, 01:46 PM
BALLSS's Avatar
if you don't know the history/age of the existing clutch...may want to put a new one in along with TO and pilot bearing (typically all come in clutch kit)
what you have to go through to replace a TO bearing...big job so unless the clutch is pristine when you take it out, replace it
resurface the FW also
Old 05-01-2012, 02:42 PM
Sales@Tick's Avatar
If the clutch has quite a bit of mileage like you say then I would go ahead and replace the clutch while you are doing the slave/throwout bearing. We have monster kits available with your choice of slave/throwout bearing. Monster levels 1 and 2 retain stock pedal feel, and when you want to have some spirited driving their there to hold up!!! Check them out on the link below:
http://www.tickperformance.com/categ...eatured&page=5
