T56 Tail shaft knocking.
I bought a t56 with the output yoke ahwhile back. There was no movement with it when I checked it over befor I bought it, but that wasent mounted up in the car where I could get some leverage. I had a custom driveshaft made for my swap car. I now have a knocking noise on an up and down movement but not side to side. See video please. I reinstalled the old yoke and I have a very small amout of play but not this bad. If something is worn, what am I looking at for parts and cost if I do it myself. If possible. Thank you for your time.
Thanks for the reply. No its not the u-joint. Its brand new and I tested it for play. It seem to be play with the yoke on the shaft. Ive talked with a few other people on my other forum that are running the same setup and it seems to be normal.
