clutch slipping
Old 08-02-2013, 05:54 PM
badamn's Avatar
Default clutch slipping
Has any one had a clutch slip because of a power steering fluid leak?I swear thats whats causing it.Only after high rpm shifts.
Old 08-02-2013, 06:05 PM
rickybobbyss's Avatar
I had a torn seal behind the harmonic balancer and the oil leak found its way into my ls7 clutch and it was slipping,i wonder if it is possible to use brake clean or such a product to clean off your clutch
Old 08-02-2013, 08:25 PM
badamn's Avatar
Yeah i had someone tell me to spray brake cleaner on it.Depends on what kinda clutch.they say the kevlar clutch i have is ruined once it got soaked.
Old 08-03-2013, 01:22 PM
badamn's Avatar
Default I guess not
I thought my clutch was slipping but this looks pretty damn normal huh?
Old 08-05-2013, 05:23 PM
stevieturbo's Avatar
clutch slipping is not normal, neither are oil leaks.
So what exactly are you asking with that last question ?
And how do you think PAS fluid is finding it's way onto the clutch ?
Old 08-06-2013, 02:03 PM
SPEC-01's Avatar
Brake-clean will not do much to help a Kevlar disc (porosity allows for absorption and this means that even if you clean the surface oil will remain within the fibers and resurface during use). That being said if you want to post pics of the parts I will be happy to help you assess them. Let me know. Thanks,
Old 08-06-2013, 03:08 PM
SNLPerformance's Avatar
I agree, feel free to contact me so I can try and help you OP. Chris, 817-750-2000
Quick Reply: clutch slipping
