Aligning shifter after a4 to t56 swap
Hello everyone,
I recently purchased a 98 Trans am that has a a4 to t56 swap. The problem is the shifter is not "centered" in the console opening. It's 1-2 inches to far to the right. When going into 5 or 6 the rod rubs the plastic, and when going into R, you have to force the shift to bend the console out a little. Can anyone give me some advice on how to fix this?
Bump, anyone have some ideas
The previous owner said it has a hurst shifter as well. Is there any way the shifter could have been installed wrong causing the alignment issue?
