Anyone review the Tick Perfrmance level 5 super magnum?
I'm running it. It shifts so much better than than the T56 did it's not even comparable. Missing a shift requires a complete screw up. I got mine with the spray oiler option and I do have it functional. It has seen 950 rwhp so far but the clutch slipped at that point. I have since replaced the clutch but have not turned the boost up past that yet. (Still breaking in the clutch)
Do you have any pictures of how you got it functional & how hard is it to get the hole made (I don't even know how it looks like) !
Clutch Choice ?
I have pics of the pump setup but I will have to upload them, maybe tonight.
When I bought mine I selected the option to have them (Tick) install the oiler. I believe you have to have the transmission apart to do this. I only had to install an oil pump outside the transmission and hook up to the already attached AN fittings. Here are a couple pics of the Tilton pump all installed. It doesn't take much. Mine is hooked to a Hobbs switch and turns on at 4 psi.
Well I spoke to Martin from Tick Perf,
The two bungs are installed to flow to the cluster gear & the input shaft. However, they should be positioned correctly.
Anyone got pictures of the sprayer bungs to have a clearer picture ? What size of bungs were used ?
I had a bad feeling not getting it installed while am ordering it.
99 NBM Z/28 M6
99 NBM Z/28 M6
