Mcleod Twin clutch light grinding noise
Old 12-09-2013, 10:33 PM
GarzaZ-28's Avatar
Default Mcleod Twin clutch light grinding noise
I recently install a Mcleod Street Twin Steel flywheel used with around 1200miles on
I just installed a new Lvl 5 Rpm T-56 M6 on my 2000 Camaro
I replaced the the master cylinder Tick and the slave Stock Gm
All this work done and here is a small grinding in the trans area.
Im baffled
Looking for answers what may be causing noise.
any suggestion?
Old 12-09-2013, 11:30 PM
BALLSS's Avatar
can you determine if noise is coming from Trans or clutch?
does the noise go away when clutch is pushed?
noise in neutral or while gears are engaged?
Old 12-10-2013, 09:52 PM
GarzaZ-28's Avatar
I dont here when clutch engaged
but when driving i here a little grinding when i come to a stop
Old 12-10-2013, 09:56 PM
GarzaZ-28's Avatar
Tansmisiion only as around 200 miles on it
Quick Reply: Mcleod Twin clutch light grinding noise
