How to identify F-Body vs. GTO Bellhousing?
The F Body and GTO bellhousing are often marketed as the same/interchangeable part. But my understanding is that they are in fact slightly different, necessitating the use of a specific starter. In other words, a GTO starter will not fit an F Body bellhousing (& vise versa).
If buying a used belhousing, how can one make the distinction between a factory F Body vs. GTO bellhousing?
Thanks.
Tipsy
Thanks.
Tipsy
From what I've gathered, the bolt holes are the same. It's the nose cones of the starters that don't interchange (please correct me if I'm wrong).
I have a GTO bellhousing and used an aftermarket F-body starter (PowerMaster) without a nose cone and it works just fine.
