clutch suggestions
clutch suggestions
ok guys, need your help. i have a leak at my rear main seal so trannys gotta come off. clutch looked low on life last time the trans was off decided not to swap it out but now its the time. currently has around 380-400hp or so but i have a new block with big turbo plans. want it to hold 600hp on the street and around 800 at the track. trying not to break the bank looked at spec and monster wondering if anyone else has any suggestions. thanks!
Sorry to say but you wont touch anything that can reliably hold that power without some deep pockets. A monster level 3 will hold 700whp and a stage 4 even more however they both are in the 600-800 dollar range. Both clutchs will have a stiffer pedal and may chatter on the street.
If you want a stock like pedal and the ability to hold even more power. Then you will creep into the $1k range with things like a monster twin disc or mcleod rxt. These will all drive like stock and hold your power.
In short there is no "cheap" clutch to hold what you want
anyone have experience with a monster 11" race clutch? says its good to 850hp/tq just want to know what its like on the street. also what exactly does the little warning mean by saying this clutch will find weak points in your drive train and if inadequate there will be failures.
PS Feel free to call to discuss, 817-750-2000
