m6 help no gear or pedal
Old 12-13-2014, 09:40 PM
nastytxz/28's Avatar
Default m6 help no gear or pedal
I was cruising just goy done with build shifted fine for 3 miles then a pop and clutch pedal got easyer to push but couldnt get car in any gears car will go into gear with motor off but will not while motor is running i have mighty vac it and old school with bleeder screw pedal stays the same im just wondering if slave went bad or pressure plate fingers broke it has a comp clutch with a tick master the clutch was used along with slave when i bought the car i reassembled motor so not to sure on conditon of throwout and slave vissaly looked good but i guess does it sound like slave or pressure plate im lost 99 ls1 fbody t56
Quick Reply: m6 help no gear or pedal
