Help with clutch
Help with clutch
I pulled the Trans to put in a rear main seal and cover gasket. I also put new fluid in the Trans. Ever since I put the transmission back in it has been acting up going into gear under normal driving. For the most part it is fine but sometimes it grinds going into gear and kicks back out of gear. I have been driving this car for 5 years and never had this problem.
The other thing it does since I pulled the trans is the pedal loses pressure under hard acceleration and won't let me shift to the next gear until the pedal pumps back up. Any suggestions on what I might have done wrong or what might not be operating right? Again the car was fine before I removed the Trans and put it back. Car is a 2001 Trans am m6
