LS7/RAM LFW or Monster Stage 2/LWF for ~400rwhp LS2 in 2800 lbs?
Trying to get off my *** and work on the project, and need to get a clutch. I see Monster has a sale thru the 1st, so now is as good a time as any. Car info:
92 Miata, should be 2800-2900 pounds when complete
'06 GTO LS2, VRX4/5 (I forget which I got) cam (with rockers), LT's, no cats, factory Z06 air intake.. otherwise pretty much stock.
'05ish Vette IRS with 3.42 gears IIRC
Hoping for 400hp to the ground
Will be daily driven foolishly with road course a few times a year (HPDE stuff, not racing per se) on race rubber, plus dragged on the street and track as needed on street tires.
The question is this:
Stock LS7 with LW flywheel or Monster stage 2 with LW flywheel?
FWIW the LS7 setup (including the heavier LS7 flywheel I believe) appears to be the standard for Flyin' Miata's conversions using the 480hp LS3. Not sure if they use it on the 525hp versions or not but I suspect they may. I've read the LS7 with RAM is roughly the same as stock weight for the GTO setup so really it seems like that is just added holding power and not changing drivability.
I don't want chatter, stockish drivability is the goal. Slightly heavier pedal is ok but don't want horrible. The Miata with the DF setup is pretty livable and it's a shade heavier than stock. Looking for roughly the same.
I'm used to a variety of setups.. former 1.6L turbo miata with big turbo and LW fly/DF setup which took more revs to launch, 1.8L turbo miata with T3 turbo and LW fly/DF setup which isn't bad and doesn't take much to get moving, the 69 Mustang with mild 302 and T5 with heavy fly but DF clutch (and I sort of wish I went LW, I think it could have used it).. so the concept of more revs to launch isn't overly worrisome, especially on a lighter Miata. I don't plan (ha) to add any significant power, so let's say 500hp is max and that is pretty unlikely.
Cost seems to be closish.. $600 for Scoggins LS7 with RAM LW vs. $734 for the Stage 2 Monster (both with hardware and LW fly). I don't want to cheap out though, so the extra $134 isn't a deal breaker. I want it right, not cheap as that is killing me everywhere I look lately!
Do I need to spent more for the Monster, or is the LS7 plenty for my setup?
Is the LS7 with RAM roughly the same weight and drivabiltiy as the stock GTO?
What's the consensus?
Given I am moving the engine/tranny out of 3700 pounds and into 2800 pounds, I don't think a lighter fly is going to be that much of a problem so I'm game to do it.
Moving from 3700 pound GTO to 2800 pound (or less) Miata, I don't think that change in FW weight will be terrible. Thanks guys!
Wallyman
you are going to be happy with the Monster. I have two Monster clutches and ZERO regrets. i think i got the stage III with light fly and the Twin disk. Do not forget to shim and if i were to do it again i would get the adjustable master from tick. a bit more pricy than other choices but the tick lets you fine tune the peddle and in the long run its the better rout.
enjoy
Maryland speed is more like Maryland slow so be patient. They will deliver EXACTLY what you order but they are very very very very very very S.......L.........O........W.....!!
enjoy
Wallyman
enjoy
enjoy
Slow might be ok, as long as it's not measured in months. I'm all for saving a buck but if they can't delver in a timely manner, that's just poor business. That should be a commodity item that I would expect any company to be able to deliver in a couple of weeks (like 2-3), even if they have to get it from Monster first. Let me guess, I'm going to be disappointed?
monster level 3 is 46lbs with 18lb flywheel
Shim - already on my list to check, thank you! I already have a new master (Wilwood 7/8") as part of the swap kit, hopefully it'll do what is needed.
