Luk Slave cylinder
Old 03-05-2017, 05:01 PM
BrBottz's Avatar
Default Luk Slave cylinder
Hello, first post ever on tech. 1999 Trans am M6 putting In a Luk LS7 clutch kit as I understand Luk makes OEM clutches for GM, My question is the slave cylinder would you use a luk slave cylinder? AP is on GM brand and luk as well as the same exact numbers LSC265B
would you chance using the cheaper of the 2? Thanks in advance.
Sorry if I'm in the wrong section.
Old 05-04-2017, 10:41 AM
Stevetrx250r's Avatar
Default Luk slave
I would also like to know as I'm in the same boat ( luk ls7 kit, f.w. and slave) for 98 T.A.
Old 05-07-2017, 01:17 PM
dan96z71's Avatar
I read somewhere that the slaves are all the same, manufactured by the same company. I went with rockauto for it as they had a great price and you can get 5% off. Was pretty cheap when you look at what others cost.
Old 05-12-2017, 12:48 AM
gongshow71's Avatar
They are all the same. LuK slave on RockAuto is somewhere around $33 dollars and its a great product. Right now I'm using a Autozone Duralast slave cylinder and it arrived with all the same stickers and pieces just like the OEM GM slave cylinder. They all come from Mexico.
I've personally used a OEM GM slave, RockAuto LuK slave, and a Autozone Duralast (FTE Branded) slave and they are all the exact same except for price.
Quick Reply: Luk Slave cylinder
