T56 or ZF 6-Speed?
T56 or ZF 6-Speed?
I'm thinking of swapping in an LQ4 into my '88 Trans Am. I've already got an LT1/T56 in there now, but I feel that the LQ4 is a better design, and I know more about those motors anyway.
Can I use the T56 from my LT1 on the LQ4, and just get the LS1 bellhousing? Or would I need something else?
if the T56 would be a big hassle, would a ZF 6-Speed work also? I know they came mated to some of the LQ4's, and there would be no problem bolting pu to the motor. Would the ZF 6-speed have any clearence issues with my trans tunnel?
How do the T56 and ZF 6-Speed compare in their ability to handle lots of torque?
If you swap the T56LT1 set-up comlpetely(assuming thats what you have) it should work. The only reason to swap to a LS1 T56 would be to get a concentric slave ( LT1 has a external slave= both are hydraulic)
