2002 T56 number of speedo "gear teeth"?
The formula to calculate my electronic to mechanical speedo converter (Cable-X) requires the number of speedo gear teeth.
Since the T56 has a VSS, what number would I use?
Here the speedo gear chart from D&D.
http://www.ddperformance.com/speedo_gear_chart.htm
Let me make sure I understand what you are asking. You are looking for the number of teeth on the speedo gear installed in your T56 now?
The old 3.36LGR used the 11T rotor. It may be hard to find one of these. If you need something close, the Viper uses a 10T . The sensor for a Viper is different and the center stack up but it may be possible to make it work in an F car.
I just need the numbers for the formula to find out how to set the dip switches in the unit.
The formula to set the dip switches is as follows:
Transmission gear (#of teeth) X axle ratio X tire revs/mile = pulses per mile
The pulse per mile is compared to a chart and the switches are set accordingly...
calculator, chart, drive, gear, mechanical, mile, number, pulse, regearing, speedo, speedometer, t56, teeth, tooth, transmission, tremec, wheel
