Spec Stage 3 clutch question Need Help.
Old 09-28-2005, 02:24 AM
SSShushu's Avatar
Default Spec Stage 3 clutch question Need Help.
Looking to buy a Spec stage 3 clutch to replace my spec clutch. Any specials going on right now? The best price I have found so far Stage 3 $435 shipped, Stage 3 Plus $559 shipped. If i want the lightweight pressure plate its another $75 on top. What differences are there between the Spec Stage3 and the stage 3 Plus. How do I know if I need to replace the flywheel also? Any posts would help.
thanks
shawn
Old 09-28-2005, 02:42 AM
greekss's Avatar
if i were you I would go with a springless setup......
Old 09-28-2005, 02:53 AM
SSShushu's Avatar
springless?
Old 09-28-2005, 03:00 PM
SSShushu's Avatar
can anyone get better pricing?
Old 09-29-2005, 09:10 AM
SCREAMIN01SS's Avatar
tbyrnemotorsports...............520 shipped for the Spec stage 3 plus
go to the spec website for more info on the new 3 plus clutch. part # SC093F
Old 09-29-2005, 02:39 PM
LS1TECH Sponsor
Sam Strano's Avatar
I can help you.... We are a Spec dealer, and I can work the prices you found. And we can drop ship the clutch right from Spec in Alabama. You simply need to call me, I'm not going to get into a big 'ol pricing war here. I'll just give you a good price as long as I know you are serious, which picking up the phone will tell me.
As for the flywheel and knowing if you need to replace it. You really can't until you inspect it. However, I'd recommend doing it with power you have and I assume you do some drag racing. The stock flywheel is just nowhere near as strong as the billet flywheels are, and when you add the aggressive clutch that makes life even harder on the weaker stock part.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
