Any way to adjust an LT1 clutch?
Old 10-04-2005, 09:23 PM
WhiteSSP's Avatar
Default Any way to adjust an LT1 clutch?
I have a 94 Formula and the clutch doesnt engage until nearly the top of its travel. I'm talking by the time its fully engaged, or what I think is fully engaged, the pedal doesnt move any further, so maybe 1-2" from the top.
Is there any way to adjust the pedal to engage closer to the middle of the range, or is the clutch just on its way out the door?
Old 10-06-2005, 11:28 AM
calhoon's Avatar
They are not adjustable.
Old 10-06-2005, 11:34 AM
Jditlfm's Avatar
Can you bleed them I can find a bleeder on mine? if so how do you replace the slave? or do you have to do everything as a whole? sorry dont mean to steal the thread.
Old 10-07-2005, 01:40 AM
ls1408cp's Avatar
There is no bleeder on lt1s. You can buy the whole assembly including master, slave, and resiovor all together from gm for a little over $200 dollars. You can use washers on the slave to space it out a little. My centerforce was the same way.
Old 10-07-2005, 02:11 PM
Trev_SS's Avatar
time for a new clutch this sounds like mine, i got a new ls6 clutch installed and it engages like a inch off the floor now there is like three inches after it engages good luck
Old 10-07-2005, 02:12 PM
Trev_SS's Avatar
Old 10-07-2005, 08:04 PM
Jditlfm's Avatar
well i just put my new clutch in, in june. So its brand new. How many sapcers you think i could get away with or do you think i can just play with it till it feels right.
Old 10-09-2005, 05:02 PM
lt1fbody355's Avatar
The reason you are prolly having this problem is that your flywheel has been turned down alot. You can use a shim behind your flywheel that will fix it but it wouldn't be very practical.
Quick Reply: Any way to adjust an LT1 clutch?
