reverse problem
Transimission Problem...reverse...
...recently i have had some problem shifting the car into 4 gear when im getting into the throttle. when i shift, it grinds the hell out of and i let off, put it in neutral, then it goes into 4th just fine. well, it just happened and when i get home i turned the car off, turned it back on and when i did this, my service engine soon light was on and the shifter was hard as hell to get back into reverse. i have to use both hands. this is scary and i really would like to get some ideas as to what the problem might be. thanks
How To Fix...
...my reverse lock-out is activated and i dont know how to fix it. its not a huge deal i would just like to get my car in reverse wihout a hassle. thanks!!
justin
justin
Check the plug for the reverse solenoid. I have never seen the actual solenoid go bad. I have seen plug & wiring issues. Did you put a skip shift eliminator on? in the wrong plug? Lastly,your 4th issues are classic worn 3/4 shift fork relm. Do a search - there are volumes of info. on that.
