Clutch line removal
Old 10-22-2005, 11:33 AM
TchargedLS1TA's Avatar
Default Clutch line removal
Ok, I know im retarded, but how the hell do you get the clutch hydraulic line off the bellhousing of a 01 6-speed??
Old 10-22-2005, 11:36 AM
LS1TECH Sponsor
Steve Burger's Avatar
I always used fuel line disconnect tools. Get the rught size tool. Push in the line and then push on the tool. It should pop off. You can use a set of flat head screwdrivers too.
Old 10-22-2005, 11:37 AM
MrEddie's Avatar
You push the white ring toward the bellhousing with flat head screwdrivers and it should release itself. I think there's a quick-disconnect tool that you could also use in place of the screwdrivers.
Old 10-22-2005, 11:40 AM
Oh, so its just like the fuel lines then?
Old 10-22-2005, 11:47 AM
LS1TECH Sponsor
More or less. The difference is that the ring on the fule line is a pull to disconnect. The trans is a push.
Old 10-22-2005, 12:14 PM
P Mack's Avatar
Some people are missing the little white ring, make sure you have one.
