question on hydrolics
Ok I recently checked the clutch fluid and it was black so my friend told me that since it was black that i needed to replace slave and master bc as soon as i replace the fluid it will go black after only a hundred miles is this true.thanks
If you haven't done it, you might as well do the drill mod since you'll be replacing the fluid anyway. Also, go get a mityvac ($35 or so but oh so helpful) to remove the air from the system.
