HELP - Connecting Manual speedometer to T-56???
Hello everybody, I've been reading this forum for awhile and I finally decided to join. I'm looking forward to learning a ton from you guys.
So, I am installing an LS-1 and T-56 from a 2000 Pontiac into a 57 Corvette. I want to keep the original 57 Corvette mechanical speedometer - how do I interface this original speedo with the T-56?
Any help you can offer is appreciated. Thank you.
I have no idea, but you might want to look into a 93-96 T56 (I dont know if thats compatible with the LS1 flywheel). Those cars still had the roller type odometer instead of digital, so I'm guessing there is a cable somewhere.
You may also want to do a search for the guys that put the LS1/T56 combo in the 82-92 FBodys. Those have cable driven speedometers and they may have some gadgets to get them working. Hope this helps, wish I had better answers for you. Good luck with the project!
-Mike
-Mike
check out www.jagsthatrun.com they make a kit to do this and i want to say its in the 150 range
and to clear some stuff up the input shaft on an lt1 trans (93-97) is shorter then an ls1 trans (98 and up)
i was thinking of the speedometer sleve kit, my bad
but the other kits ahve a core charge, so i dont know if thats means its 350+ 250 which would be 600 then you get 250 back or if its 350 and you get 250 back
