Speed Inc's short shifter?????
Search function is down right now. So I was just checking to see if anyone has this on their M6? I'm doing a swap this weekend and the shifter still has the stock stick on it. I've read how a short stick makes shifting so much easier. So how is it if you have one? Any different from the others? (LSS, UMI, etc. etc.) The reason I'm asking b/c I'm needing it by this weekend, and since I'll be in the Chicago area, I'm thinking about going with them. (b/c of time purposes)
Any opinions welcome.
Are you talking about the complete shifter or only about the stick?
I installed a short stick this evening and removed it 1 hour later!
Shifting is "sportier" and "faster". That's ok.
The reason I removed it is that you'll hear a lot of noises coming from the tranny. Just normal noises that you usually don't hear because of the rubber insulator.
Normal but VERY annoying!
if you have a pro 5.0 make sure to get something with a bend in it. I just got a lou's short stick compared to my modified pro 5.0 and its much better than stock. Only reason I switched from my modified is I didn't trust the welds
Well I just ordered the straight one Speed Inc had. I wasn't too sure about the angled one. I guees I'll see how this works and then if I don't like it, I'll switch.
