Clutch Sticking at 4th gear
Old 02-27-2006, 11:37 PM
The PAT WS6's Avatar
Default Clutch Sticking at 4th gear
When out today to pratice my launches before i go to the track on friday. and i did good till i got to fourth gear the clutch wanted to stick. I now have a LS6 Master/Slave.
Before i did the drill mod on the LS1 master and it was a PITA i didnt notice a difference at all it seemed worse i dont knw if i didnt bleed it good enough or what but i am messed up when bleeding in i think i got a lot of air in the slave.
But im sure i will be told do the drill mod on my new master but is there any other possiblity of it sticking to the floor other than the drill mod?
And when doing the drill mod all i plan on doing is pulling the master draining it, doing the drill mod, bench bleed it witht he mity vac. Install it to the pedal and to the tranny and then bleed it again by sticking the nozzle piece of the mity vac into the resvoier, correct?
Thanks for the help.
Old 02-28-2006, 01:02 AM
Super Speed's Avatar
Btw how many miles are on the clutch?
Old 02-28-2006, 08:24 AM
im amusing its the stock clutch.. but 56k
Old 02-28-2006, 10:14 AM
Sounds like its on its way out to me man
Old 03-01-2006, 08:21 AM
i re bleed the system and it is becoming better i was no agle to shift to fourth but the clutch still gets a lil sticky
Quick Reply: Clutch Sticking at 4th gear
