Master Slave question
Old 04-29-2006, 09:12 AM
MetallicaMatt's Avatar
Default Master Slave question
drill mod, clutch swap and this MF'er master slave wont go back in
does that U bolt provide support on the master slave? Or can i just use 2 straight bolts? b/c this bitch wont line up!!!
unless someone has a trick?
Old 04-29-2006, 03:14 PM
CW00BlackTA's Avatar
I think you have to use the u-bolt. Yes, it's a bitch! I had to have someone on the inside with a flashlight to tell me where to move it to line it up and to pull the u-bolt through once it did line up.
Old 04-29-2006, 03:22 PM
gettinthere's Avatar
It's a PITA with the pedals in there.
Old 04-29-2006, 03:28 PM
themack56's Avatar
Exclamation
does anyone know where i can get a u bolt so i can line up mine i think thats why mine started to leak cause it didnt line up right or if you know the part number for it, were exactly does it line up
Old 04-29-2006, 04:05 PM
damnit, i was hoping i could use straight bolts, didn't want to fight with it
time to go give it a try, F**kin thing!!
Old 04-29-2006, 09:48 PM
so everybody thinks I gotta use the U bolt? I only had time to try it for 20 minutes or so...no luck
really don't wanna spend a lot of time on this stupid thing
Old 04-29-2006, 10:59 PM
mrhzk35404's Avatar
When I did this I had a friend help me by looking with a light on the inside of the car. He would tell me which way to go. I do believe I had to sqeeze the u bolt together. It also helps to get one side started in the hole first but only started a little bit.
Old 04-30-2006, 12:22 PM
lowws6's Avatar
I used bolts on mine and its been ok for 3 years now.
Quick Reply: Master Slave question
