Why upgrade the slave & master cylinder
Do I have to upgrade them? Is it somthing you must do? Is that the only thing you have to upgrade? Im thinking of geting a ZO6 clutch kit.
The drill mod will probably help the 2-3 shift, either that or a good shifter.
From my understanding, the updated hydrolics in the 01-02's can handle more power and are more reliable. Its a bad feeling when the slave goes out on you and the clutch sticks to the floor and your car locks in gear. Went through it a few times.
Im sure somebody can explain it to me, there are a ton of threads about it on here, try searching and see what you come up with.
If you allready have the upgraded slave then I would say reuse them unless you are having issues now. I have the Ram hd setup on mine with stock items mentioned and have zero problems. I also did the drill mod too.
It may be enough to get by, but maybe not...the newer master and slave handle more fluid volume and the drill mod removes the restriction in the line so just doing one or the other won't net the same benefit. I would go ahead and do the master and slave (and drill mod too!) if you can.
I upgraded the master and slave on mine as well as drill modded it over 2 years ago. My Spec 3 is crapping out already (about 19K out of it) and I'm getting the LS7 clutch this week.
Just replace the master and slave, or you will be sorry 5k miles down the road when one takes a **** and you're pulling the trans to get it out. It's moreso preventative maintenance...just the smart thing to do.
The 02 Z06 clutch drives just like stock. IMO if I were doing a clutch I would go with something more aggressive that a stock clutch but I do a lot of drag racing.
The LS6 clutch is alot cheaper i can get the clutch kit, master and slave for the price of a ls7. Im not going to get more than 360-380hp. So that ls6 sould be gine right correct me if im wrong. What is a clutch a good clutch taht is cheap and can handle about 380hp
IM having my wifes tranny rebuilt because it grinds in 2nd so its going to be alot of money getting it rebuilt and a new clutch,master and slave. She deosnt drive it hard all the time mybe the ls6 clutch will hold just fine but my car is going to get the ls7 when it needs one. This is two cars im going to be puting clutchs in. (her T/A 99, my T/A 00)
I have a stock LS1 clutch and does ok at track its got 67,000 mile on it and its just now slipping in 2nd if i lauch hard a the track.
jk. You are lucky then. My car w/ 47k on it couldn't bare one pass without slipping AND sticking to the floor by the end of the pass.
Now I have a Ram HD, billet steel FW, and the drill mod. We shall see.
Originally Posted by ninetres
You must drive like my grandma
