T-56 fluid fill
Old 06-04-2006, 08:47 PM
rush7's Avatar
Default T-56 fluid fill
dumb question:
If I know I'm a quart low on transmission fluid, can I dump it into the reservoir under the shifter if I have it off to fix the spring? There's a hole in the bottom of the reservoir towards the back of the car that would appear to drain into the transmission.
Old 06-04-2006, 09:22 PM
wrencher
wrencher's Avatar
Ya every time I pull the trans thats where I fill mine.
But I would get the level to proper ASAP.
Old 06-24-2006, 07:24 PM
freakynipples69's Avatar
ttt, is this the easiet way to fill the tranny??
Old 06-24-2006, 07:33 PM
DONAIMIAN's Avatar
For me yes. I can have the console and shifter off in less than 10 mins.
Old 06-24-2006, 08:00 PM
could u tell me what exactly I am looking for after I take off the boot?
Old 06-24-2006, 08:14 PM
tim99ws6's Avatar
take off the boot that bolts to the floorpan of the car.
take off the 4 bolts on each corner of the shifter.
Pull out shifter.
Add Fluid.
Reverse procedure to put it all back together
Old 06-24-2006, 08:19 PM
ninetres's Avatar
Pull out shifter.
Add Fluid.
You can't over fill it this way?
Old 06-25-2006, 01:53 AM
AINT SKEERED's Avatar
Futral told me to jsut put 3 qts in mine, Is this where most of you run yours or do you put the whole 4 qts in?
Old 06-25-2006, 02:17 AM
DONAIMIAN's Avatar
Yes, but I belive it will come out of the vent tube while driving.
Old 06-25-2006, 03:49 AM
navymitch12's Avatar
get a friend to poor the fluid in the car while you are under it with the "fill" plug out...once the fluid starts comming out of that hole tell your friends to stop and stick the plug back in...put car back together and drive!
Quick Reply: T-56 fluid fill
