Removing the Actuator cylinder line
wtf, do you mean the master cylinder that has the braided line attached to it? If so then you need to take the master cylinder out of the car and theres a pin holding it to the master that youll need to push through, and "quick connect" fitting on the slave side which youll have to either use a quick connect tool, or a flat head screw driver and push the plastic peice down into the slave's plug.
