Q. on adj master. Already searched a bit.
I've been having some issues with my clutch not seperating all the way, making it hard to shift at high rpms. I already bled the thing several times with the mityvac and haven't pulled up any air.
I am currently looking at getting a adj. master form mcloud. However, after some searching it seems that it doesn't change the clutch's throw, it just gets rid of the freeplay. Is this going to help? I already shimmed it when I installed everything, so it should have enough to properly disengage. I haven't done the drill mod yet. I was going to do it today but after seeing how you got to yank the master anyway I'd rather do everything at once instead of yanking the master twice trying to fix my problem.
Or is it possible to drill out the line without removing the master? (Hidden secret second question)
Originally Posted by wrencher
No remove the master & line do the drill mod.
Then do a search & see how you can convert your stock master into an adjustable one. Then you'll be all set.
Still though, would that be enough to fix my problem or am I going to have to add another shim. Like I mentioned, from what I've read the adjustable master doesn't affect the throw, only the amount of free play. My clutch is picking up right off the floor well past break in.
wrencher
well it will change w/ the adjustable master some.
If & when you get the mcLeod, by the price sounds used?
I would highly recommend rebuilding it.
You can search here for that procedure, it is real simple.
Originally Posted by orangeapeel
The mityVac can rupture the diaphragm in the master if you put too much pressur on it. I would not go over 20 psi.
Alright, hopefully some people see this, I don't want to have to start ANOTHER thread.
I yanked my master out today, and was going to go the DIY adjustable route sometime this week, along with the drill mod.
Now I'm reading about Futral Motorsports doing a nice high output one or something that I haven't read anything about. Price is $200 though. Is it worth it to get one from him/them (don't see any info on it though on the site) or should I save some money and just mod mine? It has a little over 70k miles though.
