Can I start my engine without the trans. in?
Old 08-17-2006, 12:27 PM
dalejr8ls1's Avatar
Default Can I start my engine without the trans. in?
Should I be able to do this without a problem? I noticed when I installed my flywheel that the gear for the starter was pushed back so it did not contact the flywheel. Is that the design of the starter? I'm waiting on my transmission so I want to get the engine started and make sure everything is good there. Thanks.
Old 08-17-2006, 01:32 PM
99_Z_155's Avatar
When you activate the starter to turn the engine over, the gear pops out to the flywheel and then turns it. after you let off the key, the gear should retract back. thats why when you try starting an engine thats already running, you hear the grinding. i dont see why you couldnt start it, unless having some of the sensors unhooked from the ECM prohibit it.
Old 08-17-2006, 01:37 PM
bowtieman81's Avatar
Yep, you can start it with no trans attached. Be safe about it.
Old 08-17-2006, 01:54 PM
dalejr8ls1's Avatar
Hmm, thats wierd. I just tried to start it and it did nothing. I have the clutch peddal depressed too so the switch is engaged but still nothing...
Old 08-17-2006, 02:27 PM
dalejr8ls1's Avatar
Nevermind, the monster comes to life!! Now I cant wait for the tranny to get here from t56rebuilds!
Old 08-17-2006, 02:29 PM
Revelation Z28's Avatar
touch the flywheel, i dare ya lol
Old 08-17-2006, 09:59 PM
dalejr8ls1's Avatar
haha, na I got my clutch and bellhousing on...I would though
Old 08-18-2006, 11:20 PM
The PAT WS6's Avatar
hahah i was wondering the same thing acutally i have a post in this place somewhere boutt that. i noticed the ther starter gear was in too and was worrying
Old 08-18-2006, 11:41 PM
Ferocity02's Avatar
If your starting gear is touching the flywheel then that is bad news!
Old 08-22-2006, 04:01 PM
Blackmagic65ss's Avatar
Yea bad news if those gears are together when your not turnin the key! But yea its actually kinda cool to see... I did it the first time i replaced my clutch and to see it goin in circles was pretty cool! And you would be amazed at how fast the motor revs when it has no clutch or trans behind it to turn!
Quick Reply: Can I start my engine without the trans. in?
