Problem with Good clutch spinning
i have a spec 5, it works great, however, the pedal has backed off lately, and when in 4th, starting at low rpms and flooring it, when it spikes to full boost, the clutch will spin for like 1 second then fully engage. ( i know its the clutch cuz it makes the squeeling noise). obviously the pressure plate/bearing is not fully disengaging. this is on a stock slave 2001 t56.
i know this sounds like a total noob post, but how do i fix this? do i just bleed some fluid off or what?..
thanks
thanks
thanks
thanks
clutch is great. only downside is the squeel the clutch has. it lasts different amounts of time for everybody, but after about ~1800miles on this clutch it seems to have subsided. the squeel is real bad and embarressing...but now that its gone im reall happy bout the clutch....
