View Poll Results: How did you spend on your rebuild?
FREE!!
14
8.75%
$500 - $1000
45
28.13%
$1001 - $1500
30
18.75%
$1501 - $2000
31
19.38%
$2001 - $2500
20
12.50%
$2501 - $3000
6
3.75%
$3001 - $3500
5
3.13%
Said screw it and bought a new tranny!!
9
5.63%
Voters: 160. You may not vote on this poll
How much did you spend on your rebuild?
Just got mine rebuilt last month at a local shop but ordered the parts from T56 Rebuilds.
I wanted to do it right the first time so I had pretty much everything replaced...
-steel 3-4 shift Fork = $40
-Synchro Rebuild Kit 1-6 & reverse = $170
-Bronze Fork Pads for 1-2 & 3-4 = $60
-Billet Slider Keys 3-4 = $75
-Bearing Kit = $149
-Textralia OZ700 = $979
-Master Cylinder $139
-Slave Cylinder w/T.O. bearing = $105
-Pilot bearing = $13
-Labor = $800
Grand Total = $2530
I would also recommend checking the reverse gear while your in there, I have problems with mine going in gear after the rebuild and the shop told me the gear was probably getting worn out. I dont know why they didnt see that while they had it open!
-Bearing Kit = $149
-Labor = $800
Grand Total = $2530
T56 Rebuilds I believe it was a 4b, also.
$2100. (included a $500 Core)
Core Transmission, New 1-2 Slider, New 3-4 Slider, New 5/6 Slider, New Reverse Slider, New Mainshaft, New 1-6 Gears, Carbon Fiber Synchros, 3-4 Billet Keys, New Mikronite Finishing on 1-4 Gear, Mikronite Finishing on 1-2 Slider and 3-4 Slider, Steel 3-4 Fork, Bronze Fork Pads 1-4 forks, New Bearings, Also an 02 (casting #8) Slave CYL.
I installed a McLeod Single clutch, FW, PP and the ADJ Master w/ it. I did the drill mod when I was in there. So, All in all I spent about $2600 for my clutch and transmission.
I have never rebuilt a trany before and didn't want to pay for a rebuild.... So i did it my self and it was EASY I recomend everyone doing it! as long as you take your time and have replacement parts for the ones that are bad its CAKE! Trust me I'm no Master mech. either if you have any questions on it feel free to ask me!
Kleeborp the Moderator™
I spoke with T56rebuilds and I'm going to have one custom-built to my specs. According to them, the rebuild I'm planning on should be good for 900+hp. Included will be all the bells & whistles, including straight-cut gears...Total price? $4000...
Originally Posted by 98Z28CobraKiller
I would swap to an automatic before I spent $4K on a stick. I may go auto when my current tranny breaks.
I rebuilt mine myself as well using stuff from T56 and from AGE.
I got the bronze pads 1-6 and steel keys 3-4.
Iron 3-4 fork.
It was my 2nd manual but first T56. It was successful. But my reverse is giving me problems staying in sometimes. It must have been something you need experience to notice or something cuz I inspected the chit out of everything in it. When it's dissasembled it feels like 1000 piece jigsaw puzzle.
I spent close to a month rebuilding it. I did replace 3 gear and reverse as well so that took me a bit to round up cuz I didnt know they were gone until I cracked her open.
It is a moderate to difficult task in my opinion and you have to be well organized in what u take apart and put back together. I took pictures as well along the way. A good work bench and no time restrain will make things a lot easier.
Remember you want some play up front once u got her bolted backup she's not a T5!!! and dont take too much advice from T5 builders!!! T56 is different. If u go with a builder go with a T56 builder. She is not like older trannys in respect to tolerances.
These guys are excellent as well, and have a no nonsense no gimmick approach:
www.not-a-sponsor.com
Talk to the JR. He's very knowledgeable and the shop has a lot of experience.
Sorry dont know pricings and all but they helped me get a teflon bushing I needed as a last minute thing when I had lost 2-3 days already hunting for this 5buck item. Their shop is methodical and fukn! clean. There were no trashy looking trannys on broken shelfs. They ALL looked sandblasted clean.
Iron 3-4 fork.
last time i had a tranny rebuilt in my WS6 it was $560 at a local shop.Yesterday i watched my buddy take a T-56 apart and it seemed very simple (well not like i expected) if his goes back together well and works well then he and i will fix mine.
Since mine just wont go into 3rd, but doesnt grind so i figure there is not much wrong
Labor -free ( did it myself)
well plus some tools
my rebuild
2nd gear-103.96
1-2 syncro-118.72
block rings kit-125.78
stock shift fork pads-6.75
isolator cup-4.51
reverse gear-90.05
reverse syncro-86.88
3-4 syncro-110.25
30 pack of bud lite for the gm tech to stand there , drink and watch me- 20.00
snap ring pliers from snap off- 46.00
shop press from Harbor-150
three jaw puller - 20.00
metal strap from lowe's-6.00
pinion bearing puller (from Harbor)((to remove syncros))-10.00
Hammer (already had)-0.00
Small punch(already had)-0.00
t-40 torques bit- 6.00
15mm socket-0.00
13mm socket-0.00
4 qts atf-20.00
gm silicone-16.00
parts-646.90
shipping-12.00
labor-294.00
It pays to know people and do it your self. Not only that but i have rebuilt 7 other t-56 since then. All thanks to Scott at a Gm dealer ship near A-town.
And to top it off, i am installing my 30 spline viper conversion this week. parts total on the viper ,404.00 plus machine work(freebe), plus fluid and silicone. Alot better than 900.00 plus 250 core from DD.
Thanks to Gm Scott , and the forums, for the people that have gone before me, messed it up and posted about it.
my rebuild
2nd gear-103.96
1-2 syncro-118.72
isolator cup-4.51
reverse gear-90.05
3-4 syncro-110.25
15mm socket-0.00
13mm socket-0.00
4 qts atf-20.00
gm silicone-16.00
parts-646.90
shipping-12.00
labor-294.00
$1300.
twice.
lost 3rd the first time, had it rebuilt with a new 3rd, new syncros, steel shift forks.
2nd time, master/slave went out and a syncro broke a dogleg, so had new syncros (again) and new 4th, 5th, 6th. i think i got robbed, though, because the car drove FINE - no noise, whining, chatternig, trouble going into gear, etc etc. we didnt know what caused it, though, until my throwout bearing went ballistic 8 hours from home. thats when we replaced the master/slave, and a new throwout bearing - the return spring had dug a 1/4" groove into the housing.
twice.
Bought new trans for 2500:
30 spline mainshaft conversion - same as the Viper
26 spline Viper input shaft - bigger diameter than stock - same as the Viper
Full micropolish by Performance Metal
Cryo treated by 300 Below
G-Force solid keys 1-6 gears - replaces stock stamped keys
Heavy duty steel 3-4 shift fork
1-2 modified shift fork - steel insert
New compressed carbon particle blocking rings
Bronze fork pads - replaces stock plastic pads
All new bearings and seals
All clearances set to race specs
