Shifter Springs
Old 11-16-2006, 09:07 PM
87iroc-z28's Avatar
Default Shifter Springs
I have a question about the shifter springs. I just got this tranny so I'm not sure what it is supposed to do. The springs that center the shift handle, is that part of the shifter or the transmission? I noticed on the stock shifter when I push the handle left to the 1/2 position it will return the the 3/4 position if I leave it in neutral. However, when i push the handle to the 5/6 position it will stay there even though it is still in neutral. Is it supposed to do this? I figured it would always return to the 3/4 position when in neutral. Do I have a bad spring and if so is this something a new shifter would fix or does something in the tranny need fixed?
Old 11-16-2006, 10:05 PM
rich Z's Avatar
Shifter springs can weaken over time. Get an aftermarket shifter.
Old 11-17-2006, 03:54 PM
87iroc-z28's Avatar
So the springs are in the shifter not the transmission? I don't want to get a new shifter if it won't correct the problem.
