Slave Install Help!
Slave Install Help!
Ok I Just Installed My New Slave.. Everythings Back Together.. I Figured There Wouldnt Be Any Clutch Pedal At All When I Was Done. Its Softer Then Hell Theres Nothing There.. I Bled It About Ten Times So Far.. An Fluid Is Coming Out. But There Pedal Isnt Getting Any Different At All. I Tryed Bleeding It From The Top With The Mityvac From A Thread On Here I Saw.. But It Wasnt Sucking Any Fluid In. It Was Holding Pressure Though.. What Do I Do? Does Something Sound Wrong? I Dont Wanna Lay Under My Car Opening An Closing The Bleeder Screw All Day. Please Help!
The master is about a 1-3 hour job, I just did it and it wasnt that bad. you can find all the information you need here....
http://www.installuniversity.com/ins...sity/index.htm
alright cool. what do u think about it blueoval? do you think i just need to bleed it more? i mean.. apparently its a new master out of a 02 vette. how can i tell if its bad?
well today. i bled it from the bottom an the pedal got stiff.. but it still wont go into gear.. why not?, im bout to go by a master an install that.. but id rather save the money.. i put the mityvac on an it sucked out some bubbles.. but very very very very very small ones. i an the car still wont go into gear. so what now?
