bleeding clutch
bleeding clutch
i have bled my clutch three times in a period of two months, and the clutch pedal stills sticks to the floor. It's ok the first week but then starts doing it again, but I still have some fluid in there. whats going on
is it when you accelerate hard or when you press to put in gear? if its when you put it in gear it might be the seal in the throwout bearing that happened to me. if its when you accel it could be the clutch slipping
mines the same way....bled that ho and it worked superb for a while then started bein gross at hard acceleration occasionally after a few weeks. but i have 89k on my stock clutch, yea, a LS7 clutch is in the mail now...how many miles are on your clutch?
mine had 67k when i bought it and was slipping i then put a centerforce and got about 15k 2 20k on it. but that was with no track abuse. i now have the spec 3 and no problems with about 15 track passes
Very possible that your slave or master is going. I just did a master and slave on my 98 at 93k miles. The hydraulics on these cars are pretty weak especially with all the slamming around that we do to them. If you do decide to go with new hydraulics, and don't want an adjustable master, then I highly recommend the Wagner Master which can be found at Advance and may other part stores. If you do the slave, then no question get the Gm Upgrade that was made in 01-02. Also the Napa slaves have been know to do a great job also.
Josh
Josh
i fixed it again, but I'm pretty sure is going to do it again and is not my clutch slipping. so I may need a master and a slave. i have 63,000 miles on the car. how much would i be looking to pay for this
