Dead Pedal
Dead Pedal
I bet this has been talked about too many times but...
I have an '03 Z06 with a RAM and adjustable master. A few days ago I wasdriving and in the midle of a shift my clutch pedal went dead, as in wont come back up on its own. The clutch is less than a month old and was installed professionally. I wonder if I have a bubble in the line? No problems until now. I tried to bleed it through the master, when you pump the pedal by hand the fluid shoots up a bit out of the resavoir (sp) but it wont come back up.... Has anyone had the same kind of difficulty? The shop put it in is booked and doesn't have much input... This is where I've always found the real problem and usually the solution so TIA.
