cant downshift to 4th without grinding
Old 01-08-2007, 07:48 PM
ChevyTex's Avatar
Default cant downshift to 4th without grinding
Wondering if someone can help me out...
Sometimes when I downshift(50% of the time) from 6th or 5th into 4th gear it will grind really bad. Fluid level for the clutch is good...any ideas?
Old 01-09-2007, 04:21 PM
ChevyTex's Avatar
anyone know whats up?
Old 01-09-2007, 04:26 PM
LilSlo1's Avatar
Try cracking the throttle a little bit as you are down shifting (when you have the clutch pushed in). See if that helps.
Old 01-09-2007, 05:03 PM
02silvaZ's Avatar
might be same problem as me, shift fork going bad
