6-Speed 350 in 3rd gen questions....
Old 03-09-2007, 11:02 PM
KITTvsKARR's Avatar
Default 6-Speed 350 in 3rd gen questions....
I know this isn't an LS! question.. but.... I've got a 3rd gen Firebird that has a transplanted rebuilt old chevy 350 (bored .60 over to be either a 360 or depending on the crank a 383) matched with a 5 speed transmission. I wanted to drop both in my 2.8L auto Camaro. But an LT1 6-speed has just become available and have been told that it should match up just fine with this engine.
What kind of headaches/things to watch out for am I going to need to do with this swap? Plan is to put the v-6 back in the bird to sell it. Will that match up to the 5-speed?
Am I going to have probs with any sensors, wiring harnesses, etc?
Old 03-10-2007, 03:21 AM
slim64's Avatar
The lt1 t56 will mate just fine to the 350. But I'm pretty sure the v8 t5 won't bolt onto the v6, I believe the spline count is different. Some t5s had a cable for the speedo, some were vss, the t56 is vss so you might have to get an adapter. You will need all the clutch hydrolics from the lt1 car as well, the t5s aren't long enough. Obviously you will need to mount new pedals and cut a hole in the tunnel.
Old 03-10-2007, 05:46 AM
bumperdragging's Avatar
what tranny is in the car now? if its a 200 metric you'll probably need to change driveshafts, tail shaft on the 200 is a shorty i believe.
Old 03-10-2007, 07:34 AM
Old Geezer's Avatar
Default ????
Old 03-10-2007, 07:48 AM
fast377's Avatar
Definately wrong forum...but to answer your question it's an easy swap. Google Skulte and all the swap info is there.
Old 03-10-2007, 10:54 PM
sickwitstick's Avatar
i was going to ask a very similar question. just to make sure i understand.... a t56 WILL be a perfect swap on a 350 tpi?
Old 03-10-2007, 11:10 PM
KITTvsKARR's Avatar
Sorry for putting it in the wrong forum... but thanks for the replies. Looks like I need to start part shopping.
Quick Reply: 6-Speed 350 in 3rd gen questions....
