Could you tell me what is wrong with my car?
Ok I have a 98 TA and the car would not change into reverse unless is off. the clutch feels spongy and light, when you press the clutch there is no pressure felt for about an 1 1/2'' and when it's off I can feel the pressure since the beginning. I replace (again) the master and slave and nothing happened. it's got a LS6 clutch with about 18,000 miles.
need help please
need help please
Sounds like you still might have air in the line. Keep power bleeding it for 15-30 mins takes a while to get all the air out. Need a friend to help you press down the pedal and then keep pumping until the pedal gets hard. Takes a while. Happen to me twice. It will work
we bled it several times with same results, one thing I noticed every time we finish bleeding the clutch it was harder to shift in all gears but the next day would feel better shifting except for the reverse.
