HELP!!! trans or throwout bearing???
so on my way home i got to a stop light and herd a bearing type noise. i pushed the clutch in and the noise went away slowly. then when u release it it starts again. then if u push the clutch in and put it in gear real quick it goes away right away. is that the trans??? help me. thanks.
Doug
Doug
yeah i have the same problem,its the trowout bearing.
I'm on my 3rd clutch,I finally said enough.I went out and bought a SPEC stage 5 clutch.Its tough as hell but when they installed it they didnt get it right. now it makes this noise.
I couldnt tell ya if your hurting anything.
Is it?
Is it?
Throwout bearing, i just replaced my slave/TO bearing along with my clutch this weekend and shes quiet as can be. How much slack is in the pedal? you may need an adj. master to get full stroke.
i just found it wierd that u can hear it after the clutch was pushed for a while... kinda like the main input bearing on the trans... but if u guys thing so ill replace the master and slave... id rather do that and the drill mod and see what happends then spend $2500 on a trans.
