Which shim is which?
I have 2 shims here. I'm getting ready to use one, but don't remember which one came with my SPEC 2+ and which one is from RAM (I think). One has the holes drilled into it where the slave bolts go, and the other has the holes actually cut out from the side of the plate. If you've seen one, you know what I mean.
Which one is which? The one with drilled holes is slightly thicker, so I think I'll try the thinner one first.
agreed, i think i have an extra if you want me to take a pic
Originally Posted by BAD *** TA WS6
The one that has the slotted style holes (with the outsides of the shim open) is the one from SPEC.
