how does the reverse hook up on a T56?
here's a pic of the engine setup,
and one of my shifter setup, do i need anything else? thanx!
a long story short, if, i plug the holes, can i simply run it the way it is? with the shifter in it, and that's all....
You dont need the skip shift solenoid (CAGS) as others have mentioned. You will want the reverse light switch, reverse lock out solenoid, and the VSS of course. The reverse light switch isnt in the picture...its on the other side of the trans. The passenger side...
The reverse lock out it easy to hook up, and its a nice feature to keep you outta reverse when you dont want it. I have mine hooked up to a switch in my hurst shifter ball.
Ive seen people use plugs in the skip shift hole...just gotta do a search and find the thread size...should be able to find a plug to go in there....
Good luck! Sorry if I explained anything you already knew!
Justin
yeah would i be able to hook up the reverse lock out to just a switch? how would you do that part? my engine does have a wire setup for the vss, i'll have to see if it will fit, hopefully....
thanx much!!!
yeah i'm a newb with tranny's, but not so much with the power plants =)
