making the GTO shift knob work with Fbody?
Old 05-31-2007, 01:48 PM
u lose's Avatar
Default making the GTO shift **** work with Fbody?
since the gto shift **** is a slide and lock type.... any one make it work on the LS1 m6? i have a tna short stick and i would love to use a gto shift ****.
thanks!
matt
Old 06-01-2007, 08:36 AM
ghettocruiser's Avatar
How big is the hole in the bottom of the shifter??
Anyway, if its big enough, or if it can be made big enough, you might be able to put a threaded insert into the shifter. Epoxy it in there, and then screw it on.
Another option would be to carefully drill a hole through the side of the shifter ****, and thread it for a set screw. Or...you could drill through the shifter **** and into the shifter shaft and thread the hole in the shaft for a screw.
You could just epoxy it on there too if you dont want to take it off ever again. haha.
I dont know what the shifter **** is made up of...or what it even looks like off the top of my head. I dont know if its got metal or just plastic or what. So those are just ideas that popped into my head...
Justin
Quick Reply: making the GTO shift knob work with Fbody?
